Seems like the logical choice would be the Phazer with an 850 twin based on the 426YZF motor????
I don't think it would add that much weight.
Now that would be a pretty tough competitor!
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Yamaha will run Pro Open at the National level in Sno-X for the 2006-2007 season with a modified Nytro.
hypertxer
put a turbo or a superchager on the phazer and go out like a man
- Apr 17, 2003
- Menno, SD
- Menno, SD
The SnoX 4-stroke rules will not allow any engine that uses a gear reduction system from the crank to the clutch. Thus the only motor they can currently use is the Genesis 120 motor.
