At first I couldn't figure out why after a few little rides and my ventures plugs would blacken and the sled would not start! I thought it was the carbs and cleaned them then I thought the jets might be set wrong, and adjusted them but nothing seems to stop it from happening!Today I put a new set of plugs in the machine and as usually it started up. This time I noticed a bit of darker gray smoke for the first couple of seconds but nothing serious and then the normal smoke when starting a cold sled on a cold day! After warm up I took off and headed to the lake to cross it and go to my friends place for a quick chat! On the way the sled ran as expected perfect fast and smooth! So here I am at my friends place and we are outside talking when I hear what sounds like someone peeing in the snow! I look over and there is a stream of oil coming off the bottom of my sled while sitting parked and off! I could not locate a source for the oil leak even with the panels removed. For whatever reason I took the air box cover off and to my surprise it was soaked with oil, and of course the oil was going right down into the carbs... Think I know why my plugs are looking like it was burning rich now!
So whats going on here? Why the heck is oil coming into the breather box through the tube? I also noticed that the oil seems very runny and gas smelling even though it is fairly new oil and has not been running in the machine very much!
