08 Grizzly 350
Joe Grygiel
Age
48
St Peters
Grizzly
I have an 08 Grizzly 350 that sat for three years. I got it and replaced the carb, plug and filter. It idles and runs great up to half throttle, anything over half throttle it bog's down and loses power to you left off to less than half throttle. I put sea foam and rat it for about an hour with my son. It wont go over about 25 MPH. Any ideas of what this could be? I do not see an adjustment on the carb, I pulled the plug and its new and dry doesn't look bad. I checked the plug wire and did the ohmes test and it was good. Any help is appreciated Joe
MrSled
Site Admin/CEO
Staff member
Age
52
Schofield, WI
Website
www.totallyamaha.com
2020 Sidewinder SRX
Did you drain all the fuel out of the unit? Replace the fuel filter?
Joe Grygiel
Age
48
St Peters
Grizzly
Yes I drained the fuel tank out and the filters that I found were inside the tanks. I cleaned them out and have new ones on order.
MrSled
Site Admin/CEO
Staff member
Age
52
Schofield, WI
Website
2020 Sidewinder SRX
Are you sure you have that carburetor back together correctly? You put in a new carb?, jets? Pilots? Slide? complete?
Joe Grygiel
Age
48
St Peters
Grizzly
It came as a kit new carb not a rebuild) all I had to do was hook up the throttle cable and the choke. There was one idle screw that I adjusted to get the good idle. If I tilt the fuel tank up seems to do better. Some have said something about a clutch vent tube being clogged. I have no idea how that would affect this. Have you ever heard of that?
MrSled
Site Admin/CEO
Staff member
Age
52
Schofield, WI
Website
2020 Sidewinder SRX
Never heard of that. It sounds like the its not getting fuel at full throttle.
Joe Grygiel
Age
48
St Peters
Grizzly
Exactly what I am thinking. I have ordered a new control valve that goes on the bottom of the tank with the onn/off/res knob and then ordered a new fuel line that goes from the tank to the carb. Thanks for the replys
MrSled
Site Admin/CEO
Staff member
Age
52
Schofield, WI
Website
2020 Sidewinder SRX
I have seen the valve in the tank not provide enough flow (volume of fuel) and need to be replaced.
maim
Staff member
Moderator
sudbury on
Canada
2016 apex xtx
i have had problems with the vent line getting pinched off or plugged before. can you try it with the cap off or loose to confirm this?
mine is stuttering in the mid range from too much fuel. after 4 rebuilds on the carb, a new one is going on.
