moses3m
Went out for the first ride of this year I took my 08 phazer out everything was good untill I shifted it into reverse after backing it up and then shifting back Into forward my sled wouldn't move the track was locked up after getting it home I took the secondary clutch off and I still couldn't turn the track I looked under the sled and I couldn't find anything wrong I think there is something wrong in the chain case. My question is has anyone else out there have a similar problem?
phaze5
do you have chaincase oil? there is a part in there i think it is in the gears in the upper part of the motor, well on mine it lost the oil and they had to replace the unit that shifts it forward and reverse,
it was like 600 for that alone good luck
BombaPolaYama
I know of a case where the reverse chain broke. I don't know about the mechanics but was told that the chain for the reverse is very light duty.
moses3m
The chain case oil is good I'm taking it in today I'll let know what they find
moses3m
I just got back from the dealership and they said that my master cylinder piston was stuck and that they need to replace the master cylinder
marpolsdofer
Yep that would do it.
moses3m
They have the phazer done I pick it up tommorrow I'll tell you what our dealer here (Johnson sales ) is a great dealer they are always willing to help
- 9K
