upei93
- Apr 27, 2008
- Dalhousie, NB
- 2017 Sidewinder BTX Hurricane 270 tune
2015 Viper X-TX LE MPI turbo
Anybody have any experience with these?? Not sure I want to buck up for the K&N's and thought these might do the trick...
This kit introduces fresh air into the air box. These module filters allow fresh clean air into your throttle bodies, not heat soaked engine compartment air. This created a denser air supply, which adds 4 hp. Great bang for the buck!! These filters are serviceable and reusable after cleaning. Works great with our regulator kit. Kit comes with eight modules and instructions.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
For $45, this would be a worthwhile mod for sure, but I am skeptical.
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
you can buy the same exact kit from Denniskirk.com for $9.95
upei93
- Apr 27, 2008
- Dalhousie, NB
RIGIDONE said:you can buy the same exact kit from Dinniskirk.com for $9.95
Thanks!! Any experience with it???
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
Yea, I got them on my Phazer. They work good, I would recomend getting a Dynojet Power Commander so you can increase the air to fuel ratio since you are going to have more air going in and the same amount of fuel. Your sled might and probably will fall on it's face at high speed. Ulmer Racing & Excell Motorsport have the Power Commander and dyno proven maps to go along with it. I still get excellent fuel economy and have not scraficed any reliability. If you buy the cold air pods make sure you take out the metal rings that hold the filters in and then glue the filter in with some RTV sealant. If you suck that metal ring into your engine it is gona blow up. Get the Ulmer clutch too it works awsome The Excell Exhaust is sick too.
