Justin Porter
engine light on and sounds and can't idle by it self what should i check?
i just got it last week from someone never had any problems since 2 days ago.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Is the a number next to the engine light. Had this happen once and replaced the throttle position sensor. It just stated when riding and had to use the gas to keep it running.
Justin Porter
there is a number 33 and the light is blinking
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Coil #1 is having trouble pull it and clean it, check to see if its grounding to the head.
Justin Porter
i well check that when i get a chance to get into a shop its hard to find a warm place still winter here thanks i well post if fix
Justin, could you add your location as per site rules?
Thanks.
Thanks.
Justin Porter
Gjoa Haven Nunavut
just updated my location
Justin Porter
got it going again thanks for you guys help.
pushed in the connecting wire to the coil and light came of and runs good again
first time to have a yamaha 4stroke and i like it
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
where in the h e double hocky stick is that??Justin Porter said:Gjoa Haven Nunavut
jagabom
Isn't that like in the northern part of Canada, north of the artic circle. I think it's close to where Santa Clause lives.
Jim
08 APEX
Jim
08 APEX
- 13K
