thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
is the kill switch up?
apexmcneil
- Sep 18, 2013
- Halifax Nova Scotia Canada
- 2008 Yamaha Apex LTX
Upgrade GYTR Dual Rate shocks,
Ohlins Rear
Oillite bushing kit
Powercoated Rear skid
Snow Trackers
thor452 said:is the kill switch up?
no power is given to the cluster is the kill switch is de-pressed. so yes, the kill switch was in the on position.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
sorry didnt see you had it going was it cold when the problem was there? the starter relay in the left footwell will sometimes get moisture in it and then fail to work when it freezes. just something else to look at.
apexmcneil
- Sep 18, 2013
Ohlins Rear
Oillite bushing kit
Snow Trackers
nope, was in a heated garage. I would be confident to say the battery was dead.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
glad you got it figured out.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
As I metioned earlier, 5 years is a good run for a seasonal RV battery. I replaced my '07 battery last year after 5 years of service.
Also as I mentioned earlier, this is a good opportunity to upgrade to the 20 series battery.
Let us know what you do and if the issue is resolved with a new battery.
