tomseal6
- Aug 23, 2006
- Brevort, MI
- 4 strokes
I have a 2009 FX nytro that is running at 9000 rpm wide open on fresh groomed trail which is what I do my riding on mostly. I think the nytro is suppose to run at 8500 max. Should I add some tip weight?
New yami belt
Bender 48/40 helix
6000 miles
New yami belt
Bender 48/40 helix
6000 miles
zx4ever
- Apr 14, 2011
- Northern BC canada
- 08 nytro ty4stroke customized
Lots of people clutch them to 9000 rpm for the trail that way when they get in the powder under load it is still in the proper rpm range 8600-9000 rev limiter is at 9300 so you are fine.
tomseal6
- Aug 23, 2006
- Brevort, MI
- 4 strokes
I dont ride off trail at all, strictly groomed trail. It appears the nytro makes max power at 8500 or so? So should I add more tip weight?
tomseal6
- Aug 23, 2006
- Brevort, MI
- 4 strokes
Looks like 8750 actually. Not too far off but I still would like to pull it down a notch.
What size rivet in tip should I go to?
Jeffz
- Feb 3, 2010
- Cresco, Iowa
- 2008 Yamaha Nytro RTX 40th
2007 Phazer "RTX"
Noticed this same issue on mine while riding groomed trails as well. Actually saw 9200 and I didn't have the flipper all the way to the bar yet. Only modification that may affect clutching is a 1.5x128 track.
m.schuey7
- Feb 4, 2014
- Colorado Springs, CO.
- 2011 Yamaha Nytro XTX
Let er Rev, not hurting anything. 9000 RPM is perfect for any conditions. As long as it is not touching limiter your good.
tomseal6
- Aug 23, 2006
- Brevort, MI
- 4 strokes
Can somebody please post a dyno for a stock nytro motor?
kingedwards99
Your good! Leave it alone!
4strokes
- Mar 13, 2018
- charlemont ma
- 18 winder xtx 09 nytro xtx 06 apex gt
my stock weights wore in the middle at 10 or 15000 miles, was hitting limiter
My Nytro never liked it at 9000. It seemed to pull hardest at 84-8500. Given that you have an aftermarket helix, you may have different weights too?
If you are able to add a couple grams to the weights then go ahead and try it.
tomseal6
- Aug 23, 2006
- Brevort, MI
- 4 strokes
Everything in the primary clutch is stock.
Wrap degrees and spring in secondary is stock.
I think the motor and chassis has been broken in good with 6000 well maintained miles
tomseal6
- Aug 23, 2006
- Brevort, MI
- 4 strokes
Does anybody agree with the sled being broken in with 6000 miles?
I was never able to pull those rpms at 3000 miles.
4strokes
- Mar 13, 2018
- charlemont ma
sure, if you consider worn clutch parts to be broken in.Does anybody agree with the sled being broken in with 6000 miles?
tomseal6
- Aug 23, 2006
- Brevort, MI
- 4 strokes
Worn clutch parts with it hitting 101 mph at 9100 RPM a few days ago?
tomseal6
- Aug 23, 2006
- Brevort, MI
- 4 strokes
Good news! The tip of the flyweights have a 10.3 mm steel rivet in which gives me room for improvement to remove them and add a 17.2mm steel rivets for an additional 2 grams in the tip
