09 FX Short Track - Track Tension
Zrxpilot
Lindstrom Mn
Re-installed my skid after reworking the shocks and it seems to me my track is very tight. Didnt pay attention when taking the skid out but I believe its been this way from the factory. With the rear of the sled off the ground, I have MAYBE a 1/2" of space between the inside of the track and the rails at the widest point.
Seem right?
I would greatly appreciate any advice regarding track tension adjustment.
Seems close, run the sled on the stand some. Mine seems to change a little after I reinstall it and run it. Then you can get it aligned too.
Personally, in an effort to lessen hyfax wear,...I try to run my tracks as loose as I can without allowing the track to ratchet under hard acceleration.
