09 NYTRO XTX NEED HELP SUSPENSION.
Bowhead XTX
Michigan
Basically I am a novice working on sleds. I just put 152 woody's mega bites in and added 6 dooly bars. Well my problem it wants to push in corners really hard if you ride fast it wears you out. I am looking to control the push. If you have any ideas what to do to help i would greatly appreciate the help
Also what would be a good ski to put on it. I was looking at Slydogs. I live in Michigan were the trails get ice, Hard packed, deep powder in the Upper. i only have 500 miles on her.
Do some reading man..heard the slydogs wor well..I just have stock ski's with the worn out ractory carbides w/144 wody's. I just rider haha but do some of the tips located on the sticky's such as the front rear shock etc. that should help ya.
I live in two places Linden Mi and Flatrock mi.. But I mostly ride in the Upper since I use to live in Newberry! My job is in Flatrock and I live with my girlfriend down there!
if you want I can tweak your supension for you since you are coming through my area often
Another thing that may help, is getting used to the difference in cornering a 2stroke vs 4stroke. Throttle control is crucial on a 4stroke. Dont get in and out of the throttle, keep it steady and smooth.
I run my limiter strap in the Top hole(loose) and the front shock(skis) springs with 0 pre-load.This would typically give you alot of push, but surprisingly it carves pretty well without a chit load of heavy stearing.
Edit Sorry, mis-spoke, I run my limiter strap in the second hole down.
Change out the skis for a set of skidoo pilots. It makes a huge difference. Its the skis that suck.
I don't know about your suspension, but if you have the original type of Dooly's you will get a lot of push...As long as your suspension is set up properly than I would think your cheapest route would be to replace the Dooly's with Deuce Shaper bars, triple points, or Snowtrackers...
