09rtxphazer
- Nov 15, 2011
hey all Iam new here and new to my Phazer.
I sold my 05 mach z and picked this up.
hopefully it was a smart move.
any tips tricks sugestions ect would be cool trying to go over it and get ready for snow
tnx Matt
tnx Matt
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
Just do all the preventive maintenance you can.Things such as bearings,clutches,bushings and oil changes.Normal stuff.Then go on your first ride with a open mind.Start of at a slow pace.Then think riding a dirtbike.Dont let others push you till you get a feel for this style of riding.Stop often to make suspension adjustments.Once you have a good amount of time on it.Start tailoring it to your needs.Preferably during a winter thaw which usually happens and you cant ride anyway.Do not think that just because a issue is posted here that you will be affected by it.Use search for specific issues you have or improvement you want to make.Keep it simple and ride as much as you can.
Groomer08
your prob gonna want UP bushmans steering kit. these phazers have plastic bushings that go out quick stock.
jack up front end and look for slop. a arm bushings go too as they are plastic as well.
Ruckus
Reserved for future comments.
09rtxphazer
- Nov 15, 2011
todays phazer report
seat had a little tear in it bought a cover having it put on tommorrow.Iam looking for 1 lower a arm the kid i got it from must have hit something with it and had someone weld a piece of angle over the dent. other than that it should be good its only got 797 miles on it he also put 48 studs in track that were pretty worn out so i need to replace those and maybe add a few idk
