natedogg3
during riding last weekend i noticed that i lost my taillight, reverse alarm and yama heater. when i got home i checked the fuse box to find the SIG fuse blown. no biggie, changed it, started the sled and it blows the fuse immedietly everytime. removed the yama heater thinking that was the issue and it is not.
any other suggested things to check????
smalltownpower
heated shield connection grounding out?
berge75
Ceck the tail light wire routing,there's alot of sharp edges it get ran around
natedogg3
berge75 said:Ceck the tail light wire routing,there's alot of sharp edges it get ran around
did check this and the wire seems fine!!!
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
If it pops right away you have a short somewhere. The signal fuse protects the sled from these circuits:
37: DC back buzzer
38: Gear position switch
39: Brake light switch
40: Tail/brake light
37: DC back buzzer
Yamahajrp
i hate electrical issuse seems like a needle in a haystack sometimes....good luck with finding it.
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
Yamahajrp said:i hate electrical issuse seems like a needle in a haystack sometimes....good luck with finding it.
X2
natedogg3
GOT IT!! thanks for all the help TY. Former owner had hardwired a heated shield wire into the tail light and the wire had started to rub through causing the short and popping the SIG fuse.
thanks again
Nate
thanks again
Nate
