Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
For those of you who have installed a 1.5" track - Does the taller lug cause a clearance problem inside the tunnel?
I've installed a 1.5" lug in my Nytro. But I've also removed the tunnel protectors - in order to reduce the amount of snow and ice I would end up hauling around in the tunnel. However, I've noticed that I can reach inside the tunnel and push the track up to the point that it comes in contact with the exhaust.
Has anyone else come across this? Am I going to have a problem?
p0wd3rp1l0t
from what i've heard it shouldnt be a problem...but anything over 1.5" will not clear unless u switch to 8 tooth drivers
