yamahahaha
i have a 1" track with 196 studs thats almost mint, off dads old turbo rx1, i think it is a camoplast hacksaw, or maybe a carve...? my ripsaw is starting to go and most of the studs are bent on it. will the 1 inch hook up the same?
yamahahaha
the track on it now has 144 studs
ShootToThrill
Prolly won't hook quite as good but the sled will be more fun to ride. The rear won't be as planted and this helps with some of the steering issues. Put a set of pilots on it with shaper bars. You won't believe how much difference it makes.
Rayman5271
- Oct 3, 2009
- Northern Maine
- 2016 Yamaha SR Viper XTX SE
I know it sounds crazy, but I think you will find it hooks up better because of the stud pattern. And with this sled, the centered weight and the suspension design, I don't think you will be hard up with any track.
yamahahaha
even though the 1 inch has 48 more studs...
ShootToThrill
yamahahaha said:even though the 1 inch has 48 more studs...
The ripsaw has good hook on sloppy trails, slightly better than most inch tracks. Any other time it's a wash. Seems to me the ripsaw has to much bite through the corners.
yamahahaha
Rayman5271 said:I know it sounds crazy, but I think you will find it hooks up better because of the stud pattern. And with this sled, the centered weight and the suspension design, I don't think you will be hard up with any track.
the 1" w/196 studs will hook beter?
