yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
has any one put on the larger 10 gal fuel tank with a mcx turbo? can it do or is there any pictures out there? i hear the lintake pipe is causing some problems and they wont fit is this true?
thanks
thanks
CCLLC
- May 3, 2007
This is true. We received a MCX equipped Nytro this past Monday to look over. The charge tube is hitting our tank (it was hitting the OEM tank on the sled we have!). So we are reworking our mold next week and will have this resolved within a few days. Doing our best to make our product work for as many sledders as possible.
Thanks for your patience.
Seth
TrailTank
www.trailtank.net
503.318.3139
Seth
TrailTank
www.trailtank.net
503.318.3139
yukon yamaha
- Jan 30, 2008
what would be the chances of using a heated metal tube in a vice and pressing the tank over it to form it the the intake tube???
i have three here and i wounder if it would be worth it or would it damage the tank too much??
PwdrNut
- Jan 16, 2005
- Salida, CO
- www.haboost.com
I have a tank that fit on with no problem, although there is no room to spare. I believe it just depends on the location that the charge tube hole was drilled, so there is a chance the tank will fit without any modifications.
From my understanding, Seth is re-doing the mold so that there can be no issues. It is good to see a company working so hard to modify a new product so that it fits everyone's needs.
When MCXpress was installing their tank, it hit the charge tube. They heated the tank and used a metal tube to form the tank so that it fit. I think this would work better than heating a tube.
Doogs
CCLLC said:This is true. We received a MCX equipped Nytro this past Monday to look over. The charge tube is hitting our tank (it was hitting the OEM tank on the sled we have!). So we are reworking our mold next week and will have this resolved within a few days. Doing our best to make our product work for as many sledders as possible.
Seth
TrailTank
www.trailtank.net
503.318.3139
Could you guys rework the mold to use dzus fasteners too? I would order a tank except I don't like how it uses regular screws.
PwdrNut
- Jan 16, 2005
- Salida, CO
- www.haboost.com
I have replaced the regular screws with thumb screws so that you don't need a screwdriver. These aren't as quick as a dzus fastener, but much easier than the phillips head screws.
