Ruggybuggy
- Sep 1, 2013
- Kenora, NWOnt, Canada
- 2007 Phazer FX 144
The Apex part number is 8HG-F3711-00-00 and the Phazer uses the 8EX-F3711-00-00. Are they interchangeable and will all the hardware bolt on? It looks like a completely different ski. I know it's the same width because the mounting bolt has the same part number.
Ruggybuggy
- Sep 1, 2013
I think I figured it out. The Apex has power steering and because of this they designed the ski different. Also the knuckle is different.
The ski from a Apex will work on a Phazer. You will use the same ski rubber.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
06-10 Apex skis fit up exactly. Only difference is the keel depth. The phazer keel is not as aggressive.
Ruggybuggy
- Sep 1, 2013
So does the ski hoops and carbides from the Phazer bolt up? I just ordered the stock skis but do have a little time to change it.
Malibu
we have different skis in scandinavia.they are caled crossover skis.pun mine on my brothers Pz rtx 09
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Not sure if EPS ski will accept phazer loops and runners. Why not just order correct ski? I have lots of phazer skis in stock.
