mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
Would they clear in the stock apex tunnel using a 0.525" ice racing track and ice picks?
Need to know as this is my only option to get any taller gearing using stock chaincase now.
HURRICANE
I'm quite sure that there isn't room for the pics whith 11 tooth drivers,however,there are other gearing options.
DC5
It won't fit without an extended chaincase. You can gear for well past 200mph with 10 tooth drivers and stock chaincase.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
Then,,, HOW, where.... ???
I am at top 26 bottom 33...
Can find ANY other gears.... anywhere?
There are some mighty Z1 turbos around here that I think will put my radar apex sled to back of pack if I don t do anything in this regard
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
mulot30th said:Then,,, HOW, where.... ???
11,000 engine RPM with 26/33 gearing with 10 tooth drivers and 10% over drive you should get 185 mph!
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
I DONT use overdrive... never did on radar and will not.
I dont have enough HP to be inneficient.
I will not hit my target mph using my current gears for sure.
aja636
Look into a bigger secondary clutch....STM has them and we had it. Had to gear lower to make up for it. That changes you over all ratio.
With the STM 11.25 tuner secondary clutch we ran 22/40 gears, 10 tooth drivers and we were seeing mid 120's on a good tight hard pack track, and low 130's on Ice. This is 1000'
DC5 how did you make out with my old AVID chaincase?
DC5
Your old chaincase will be in my radar sled this year. I have not installed it yet. Mulot, micro belmont will make you any size gear you want for the bottom. I have a 30 and 31 tooth for my apex.
lakercr
Tech Advisor
What is your target MPH? What kind of surface (ice, snow...)?
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
My target mph is whatever I can go on a full weight full bodied apex with no aero mods done to it (not a fake full body a la cpr...!!!) .
Last winter, 283hp on hurricane's dyno and I did 168mph on ice in 2000ft, sled + driver weight was 970 pounds using a 136x15" 0.525 ice track
My guess on the limit is as good as yours... I really don't know.
lakercr
Tech Advisor
What was your RPM doing for the 168 run?
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
10500-10600 rpm... around that...
Only way to do it was to lest it go a bit in overdrive..
Engine would not make power past 10500 for some reason... I had many issues with engine, head, efi etc... last year...
