birkebeiner
- Jul 27, 2009
- Norway
- Norway
- 2015 Yamaha SR Viper X-TX
My XTX didn't have 12 DC outlet mounted so I bought the OEM outlet. But does anyone know where to connect it? I can't find any spare connector under the hood...
redrider18
It should be on the clutch side, above and behind the secondary I think.
Installed the OEM Yamaha 12 Volt kit today on my XTX 2011. As Redrider18 says its located on the clutch side, it has a dummy plug you have to remove. Its a 5 minute install.
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Picture?
I'll have a second look
NorthernNytro
birkebeiner
- Jul 27, 2009
- Norway
- Norway
mathis said:it has a dummy plug you have to remove.
Got it
Mine blows the 3 amp fuse often. Any ideas what it could be?
Off Trail Mike
Gone Riding!
- Dec 26, 2009
- Bathurst, NB, Canada
- MTX
vector06 said:Mine blows the 3 amp fuse often. Any ideas what it could be?
Your 4 amp load!.....LOL Sorry, couln't resist.
Check for a freyed wire where the connector is. Had fixed one once that was rubbing on the radiator mount.
OTM
