DC OUTLET
I know these came as an option so is there a plug in the wiring harness there that there don't use if you don't have one. I would think they would use the same harness and just plug or tape it off since the fuse is there.
I ordered them from cyclepartswarehouse.com for I believe $45.00 each plus shipping. The bad part is that Yamaha has them on backorder. They are the factory part, so it plugs right in to the harness. I did a bit of research on them, and found that the part number is the same on an 06 Attak as my xtx. Tried to find a totaled sled and just take the DC outlet, but no luck finding one.
snowracer1000 said:
Remi said:
Yes, if you buy the original, it's just "plug&play"
But were is the connector I have one that looks like the connector of my apex but it has a plug in it with no wires, is that it?
That I dont know, I prefer to have 12V all the time, so I've made my own wiering and saved 90% ;)
Snowracer the 08 model is not plug n play. 09 plugs right in.
Most likely. I'm not sure about the Apex, but on my Nytro the plug was hidden behind the left headlight support. Remove the dummy plug and plug in your 12V adapter plug.
