12 mm sway bar
4bangdan
Fort Kent, Maine
2004 yamaha rx1 2015 yamaha apex xtx
i have 03 rx-1 with longer links. i'd like to go with 12 mm bar. do i need more parts or will it bolt right in? cheapest place to buy also?
sway bar
you will have to get a bar with the same steped ends as your 03 bar other wise you will need to buy new links off of an 04 or newer rx 1 as there not steped.
Did you find a 12mm bar to fit your 03 longer links?
I also have the longer 03 links and would like to get a 12mm bar without having to buy new links.
I used to have a 12mm bar with the 03 longer links and broke two bars because the bar for those links is very skinny compared to using a bar and long links for an 04 or 05 sled. Try pioneer perf. or Bender racing. I just got mine (13mm bar and links) from Bender 3 weeks ago.
I just spoke to Bruce at Pioneer. You need the 04 style links for their 12mm.
I'm going to buy the 11mm bar and 04 links that Ted Jannetty is selling. Then I'll have the upgraded links if I decide to buy a 12mm or 13mm bar.
Trust me you will end up with either the 12 or 13mm bar!!
