I'm planning on going from 121" to a 136" track on a 2006 Apex GT. My question is should I put the fat boy spring in the skid. Would it help or hinder or is it not needed. I weigh 215 lbs.
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
I have pretty much baught an Attach skid. The member I'm buying it from has the big boy spring and I will be using it. I am around 205lbs, but I ride agressively and I was consistantly bottoming out my stock 121 Mono. I had it cranked up. With your weight and If you like to run through the moguls like I do at high speeds, I would get the spring.
1CS
1CS
