YammiMoose
- Mar 18, 2004
- In a place where it SNOWS every day
I attempted to install the 12mm bar supplied by Pioneer 2 weeks ago while on a trip. I ended up putting the stock one back on.
Here's the issue. I could not get the arms to line up to allow me to put the bolts back in. I would line up one and the other would be way off. I must have played with it for over an hour. We even placed both the stock one and the 12mm on the bench. On the stock one both arms would lay flat but not with the 12mm one. One would touch and the other would be about 3/4 of an inch off the bench no matter which groove I put it in. I am not referring to the bolts that hold the arm on to the new shaft. I am talking about being able to bolt it back onto the sled.
I spoke with Bruce who had no issues with me sending it back but I figured I would ask here before sending it back.
Thanks,
-Moose
Thanks,
-Moose
sawsalesman
LazyBastard
I'm not sure if it matters, but did you try FLIPPING the arm?
YammiMoose
- Mar 18, 2004
LazyBastard said:I'm not sure if it matters, but did you try FLIPPING the arm?
Yes, it also suggests that in the directions if you encounter issues installing.
-Moose
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
was the sled in the air like pictured ?
if so...any chance you tweaked something on your sled?
YammiMoose
- Mar 18, 2004
sj said:was the sled in the air like pictured ?
Yes, I am the only one that has ridden this sled and never hit anything. Well nothing that would cause the front end to be damaged..... The sled has no darting or wandering issues...
-Moose
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
when you attempted to install the bar....the sled needs to be in the air with load off the suspension....was it?
YammiMoose
- Mar 18, 2004
sj said:when you attempted to install the bar....the sled needs to be in the air with load off the suspension....was it?
Yes, the front end was up in the air. I might have been able to bolt everything back but I would have had to really force it.
-Moose
blue er
with the extra stiffness of the larger bar you may require the use of an aligning punch to get the bolt started.
Coondog2707
Without hijacking your thread, I was interested in upgrading to a heavier sway bar too.
Is there more than one diameter available? I have only heard of 13mm before this post.
What is the stock diameter?
sawsalesman
Stock is 11mm. You can get a 12 or 13mm.
Coondog2707
thank you
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
Had the same problem , the bar is made wrong , exchange it and it will go togeather in 10 mins.
The knurl is indexed wrong !!
YammiMoose
- Mar 18, 2004
gsxr said:Had the same problem , the bar is made wrong , exchange it and it will go togeather in 10 mins.
I was waiting for someone to state this.. It seems like a very straight foward install. Sending it back today.
-Moose
