TLiddicoat
- Oct 10, 2011
- west bend WI
- 2013 Nytro XTX backcountry 1.75"
Is there a stock fuse for the 12v accessory plug pigtail that is located on the side of the headlight assembly? I installed a 12v plug and used the stock plug pigtail. While riding, i noticed the plug came out of my helmet, was draging in the snow and stopped working. The male part of the plug works in other sleds so i know its not the fuse in that so the only other thing i could think of is if there is a fuse for that pigtail from the factory that blew?
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Yes should be in the fuse block labeled auxiliary DC jack fuse.
Pete
Pete
Yannie
- Jan 5, 2014
- Winnipeg
- 2010 Yamaha Nytro RTX
The fuse block is by the chaincase.
TLiddicoat
- Oct 10, 2011
- west bend WI
I cant seem to locate the 12volt accessory one. My sled is packed full of snow and ice from riding. Does anyone have a pic they could post of the actual fuse and location. Much appreciated.
poor farmer/logger
- Dec 3, 2012
- Saskatchewan
It should be in your owners manual. It's in the small block of fuses on the right hand side back by the foot rest area. I think it's even labeled inside the cover to tell you the truth.
- 6K
- 13K
