12V electrical outlet?
Metallicat
Northville, MI
My sled doesn't have the 12V outlet installed. Tonight I pulled off the panel in front of the steering column which encompasses the key switch and found a white 2 prong female quick disconnect terminal that is plugged. Is this the terminal where the 12V connector would plug into? It is right next to the disconnect for the key switch. Just curious!
Thanks!
Mike
Will a pic help?
Ok, what is it???
That is what I thought. Was the 12V always an option or did it come standard on some models? I was sorta surprised that my Vector did not have it as a standard feature. I might want to add it sometime in the future just so I can use my GPS.
Tork said:
searching my memory bank for someting I did 2 years ago........
yeah that is the plug I am 95% sure.
My LTX GT has it as a standard item. Sorry, I didn't remember to take a look under the top-cover where it connects. I was too exited when I picked it up from the dealer 4 hours ago... ;)!
In 05 anyway pretty sure it was a $30ish optional kit.
But as the post above reads, maybe it came with the GT models starting that next year
Yep, that's the plug, I just did both of my Phazers.
Some models had the wiring and others didn't so making a blanket statement that you can plug and play just wouldn't be right.
Sure is nice when you can though. :Rockon:
Congrats! Now post some pics of your blue beauty!
Cool! I think I will add it to mine.
This is how mine is connected... ;)!
The ignition-switch on the upper left, and the 12v-plug on the upper right...
HEY BUDWEISER YOUR RIGHT ON THE GT MODELS WITH THE 12V ACC.PLUG BUT THE O7 SPECS THAT SHOWED THE VECTOR RTX FOR 08 STATES THAT ITS STANDARD ON THEM.HAVENT HAD A ANSWER FROM YAMAHA OR THE DEALER EITHER. THE TWO WIRES BY THE KEY SWITCH ARE THE RIGHT ONES. :Rockon:
