stevieu1
I've had my 06 for 12 years. I've never touched the clutch other than blowing out with compressed air periodically. I found a clutch rebuild kit from spi. It looks like bushings, washers and such. I thought it couldn't hurt to get it. Anything else I should look for while I'm in there?
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I not sure if you need more I just remember having my 06 Apex rebuilt after 10k miles and the mechanic saying he could not believe how great it still looked and functioned, hope yours is just as good
RIKMAN
- Feb 21, 2008
- Val d'Or, Qc
- 2020 Srx
That’s all you’ll need for the primary and mite as well change the secondary bushings. Keep an eye on the primary spyder for stress cracks while your in there. When i did mine, i found a crack in it.
Cheers
Cheers
horse puppies! mine is at 13000 mi ish and did not have any play when i checked the rollers and weights doing its pre season 2 months ago.
iceback
16000 on my Apex max , inspect it , clean it run it .
72Gran
- Jan 25, 2009
- 92 Vmax 4
21 Sidewinder LTX GT
98 Venture TF
50k on my LTX and 20k on my XTX only ever changed secondary buttons, clean and run. Clean with brake cleaner it helps wash out the dirt from hidden areas. I clean every 2500k.
Firedawg1998
- Oct 17, 2018
- Sudbury, Ontario
- 2019 srx
Hurricane PM bundle
2012 apex xtx
2012 vector gt
Mines at 14,000k and still smooth operating. I would always be concerned with replacement parts that aren’t Yamaha. Those to me, are made of the best quality material one can manufacture with which to me is why stuff last so long on these darn machine. I’ve heard of bearing laston less than half of the originals. Someone put API or kimpex secondary buttons and they destroyed themselves in a shocking time frame and then reinstalled the partially worn Yamaha ones back in.. for me, when I remove a Yamaha part. That’s what goes back in its place so I can forget about whether it’s a quality part or not.
Now let’s not mention the front bushing, oilite has that figured out, lol
stevieu1
All great replies, thank you!
Pete_man26
- Jan 22, 2015
- Yamaha Attak
replace the springs as well. For 20 bucks from Yamaha you each can't go wrong.
I Replaced all . Complete clutches , the whole thing , both .It makes a difference, just replacing what your replacing will help .Yamaha clutches work well but after time and how much your right thumb pushes makes things wear sooner or later .
