stretching to a 136", already have the new 136 cobra sitting in the shop,,looking for opinions on what tunnel extension to get, and should I get the rails from Ulmer or do the tracks usa extensions work ok??? Not an off trail rider so 144 didn't work for me. Have had several 136 length sled and they worked well so the choice was easy,,,thanks
towerrigger
I would just order the tracks USA extensions, If you really like the length then you could order up some rails from Ulmer. His rails are a bit beefier than the stockers. Tracks USA extensions are supposed to be the best out there.
RowdyRoddy
- Nov 4, 2007
- Corner Brook, Newfoundland, Canada
- www.westernsnoriders.ca
towerrigger said:I would just order the tracks USA extensions, If you really like the length then you could order up some rails from Ulmer. His rails are a bit beefier than the stockers. Tracks USA extensions are supposed to be the best out there.
I've heard the same thing about Track USA extensions. Lots of guys swear by them.
RR
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
I have Tracks USA extensions available with our tunnel extension for those that don't want or can't afford a billet rail.
