Blue shadow
I plan on changing my track this year to a 153 or longer .To much power on 20 psi on snow with no studs .I don t like the track angle on the oem syspension ,so I was thinking of moving it back enought to make the 136 rails work with the 153 inch track .Would this work ?thanks
Need for Speed 2
I wouldnt go more than4inch on set back and at that I would run anti stab wheel kit on front rails, it will help with the angle and a few other points of interest.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
Blue shadow said:I plan on changing my track this year to a 153 or longer .To much power on 20 psi on snow with no studs .I don t like the track angle on the oem syspension ,so I was thinking of moving it back enought to make the 136 rails work with the 153 inch track .Would this work ?thanks
install a 136 to 144" kit from tracksusa.
then set it back 4.25" and you will have a great setup for the mountain
but 153" and 20psi of boost will go..... nowhere...
Ive tried 153" and 10 psi of boost and it got nowhere... minimum required is 162"
Blue shadow
mulot turbo this is for straight drags only at 660 ft .I have 120 pounds gone off the sled as of now from stock .So you think that a 153 wont be enough for traction on a groom track ?
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
Blue shadow said:mulot turbo this is for straight drags only at 660 ft .I have 120 pounds gone off the sled as of now from stock .So you think that a 153 wont be enough for traction on a groom track ?
I did not think you need any more thant 144" for dratg
