phazermtxrider
im going to try the longer track, is a 155 the best i dea with moving the skid back or woud a 151, or 153 work?, what brand and type track, i want something really flexable, so paddles dont rip as easy. any help would be greatly appreciated! also what was the track angle of stock mtx veses other mountain sleds?
MOUNTAIN VMAX4
If you are looking to stay 2.52 then go with a 151 or 153 I think you can get a 2.52 in either, and I would go with a Camoplast Challenger or Challenger Extreme. The 155 is 2.86 pitch.
jlparker77
153 is 3.0 pitch
phazermtxrider
i know a 159 is 2.52, i also herd that the new cat track is good its a power claw, but its onlt a 153 and 162 and wronge pitch
yukonranger
I say run whatever track you like best you're gonna have to take the drive axle out anyways so you might as well upgrade to extros while you're in there.
phazermtxrider
what size track so you guys think would be too big for a phazer to pull, i know i want bigger than a 151 but dont know where to stop
jlparker77
I think the 151 is about the perfect track on the phazer, i have wanted to do it to mine, but haven't yet.
It gets you the approach angle that you need by moving the skid back and no need for extensions.
Plus they are very easy to find used.
The next logical step up in length I think would be a 159.
phazermtxrider
does anyone happent o know the aprotch angle of the phazer and a polaris rmk to c the differentc
jlparker77
I don't know the angle. But i do know looking at my vector 151 and phazer 144 on the trailer, there is a huge difference.
they actually have almost exactly the same amount on track on the ground. The difference is made up in the approach angle.
The vector is 10 times the powder machine that the phazer is.
MOUNTAIN VMAX4
A 156 is a 2.52 and that would be perfect I stand corrected on the 153 sorry for giving you the wrong info. Thanks for the correction I forgot about the 153 being a 3 in pitch.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
The "MTX" should have been called an XTX from the factory. I've always wondered why the tunnel is SO LONG for only a 144" track, I wonder if they had originally planned to have a 151" track from the factory and they changed it to a 144" just before release. Yes the approach is horrible, but not quite as bad as the short track phazers.
phazermtxrider
what sled did the 156 2.52 track come out of or was it just something camoplast made?
MOUNTAIN VMAX4
Camoplast
Just one camoplast made. Not sure if they make it in 14 you may have to cut it down. Look at tracksusa.com for a list of all mountain tracks.
