DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
What drivers and stock gears with the xtx 137? That is awesome speeds with PT tune,ta I understand its speedo not gps,but for that big track,thats motoring,and all with the 8dn belt,and stock helix and spring. Congrates
Same gear and drivers as your LTX
budman 1000
- Jan 22, 2010
- Saskatchewan
- 2023 Yamaha LTX GT, 2017 Sidewinder XTX LE 137; 2015 Apex xtx, 2010 Nytro xtx turbo, 2008 Apex GT 40th, 2008 nytro rtx, 2005 RS Vector MTN turbo, 2001 VMAX 600
I tried with the mid empty on the weight and my rpm was about 200 rpm high, one of the guys the sight here recommended adding weight to the middle and so I tried the 4 washers, 2 on each side and it worked.Was your clutch set up from allen ulmer always set up this way? Mine to was two tungstens in tip,BUT mid always empty,and heel only has had two washers in them,one on each side,but when I last contacted allen last week,he told me to remove one tungsten in tip,and keep 4 washers on that side,leaving all else the same,the only diff,between our set ups is my stm 38 came with my kit,and allens red secondary spring which is a cat spring,set at 01 wrapped.Oh ya,what lug is on your track?
I believe if you go up in helix angle you require less weight on primary which could explain your setup with the 38 degrees helix.
My track is the 1.75 “ lug backcountry which came on this model of sled. 2017 Xtx Le 137
budman 1000
- Jan 22, 2010
- Saskatchewan
This model has same gears and drivers as the ltx models.What drivers and stock gears with the xtx 137? That is awesome speeds with PT tune,ta I understand its speedo not gps,but for that big track,thats motoring,and all with the 8dn belt,and stock helix and spring. Congrates
I am very impressed on how the track is standing up to the power, and speed.
I think back to my Vmax 4 days and I could shread Yokahama track in one day, I sure don’t miss that quality of track!
budman 1000
- Jan 22, 2010
- Saskatchewan
Interesting, I thought from everything I read on here 57 was the magic number!I will measure C to C and see where I'm at as well. Im also at 57mm currently and going to work out to 59mm to start.
I might grab some popcorn and climb on the fence before I machine my clutches to get to 57.
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
Don't drink that koolaid unless you have heat and are blowing belts!!
I am moving outward from 57 to 60 myself.
