13mm sway bar in my Apex
bbjorklund99
Minnesota
I just wanted to say thanks to all the guys that encouraged me to put in the new 13mm sway bar. I installed the sway bar in my 07 Apex GT and wow!
I thought the sled cornered nice before I install the sway bar but the new sway bar makes it amazingly flat cornering. I would highly recommend this upgrade to anyone with an Apex.
Brad
I'm in Canada. Where is the best place to get the 13mm sway bar, do the dealers have them? I am adding Slydog Race Skis to my 07 Attak next week with the 7.5" shaperbar carbide. I just want this thing to handle better. Am having the A-arms levelled out now as well. Tips appreciated. I run with too many ski-doo guys & want it better in the twisties.
i purchaced mine from modfather in Warminister near Orillia 1-705-327-7914. It does corner alot better and helps stability when you loosen springs off to lower sled
Changing the sway bar is about a 10 minute job and costs about $90 from Pioneer. I haven't ridden mine yet since switching because that project was one of a few others (CR10EKs and 23-tooth upper gear) I was doing simultaneously and the sled is still on the lift table. Even before that change, that Apex handled tight trails easily on a par with the Revs I ride with.
