hook-n-book
Was wordering if any one was thinking of running the 14 inch track on there attak, And will they fit right. Thanks
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
I'll be running a 14" x 136" track in a '06 Apex GT that I'm stretching out to a 136" using a Pro-Active CK w/Ohlins.
I had this style track in a 136" Viper previously and really like it. It's nice and light, plenty durable, and really hooks up in good snow conditions. It all depends on how you want to set your sled up, and the conditions that you'll be riding in the most.
The track will fit just fine. It's 1/2" narrower on each side, and the center distance of the windows is the same as a 15" wide track. With the 1.5" outside lugs you'll either need to remove the tunnel protectors and front heat exchanger protectors for clearance or notch the lugs. You can still run the stock 9 tooth drivers, or install extrovert drivers as I did since the track has all the windows open and is fully clipped.
hook-n-book
Thanks for the feed back VX7R I was hoping that it fit , How is the side to side handling , Is it lite enough to notice the differnce between the 15 inch and the 14.ThanksVX7R said:I'll be running a 14" x 136" track in a '06 Apex GT that I'm stretching out to a 136" using a Pro-Active CK w/Ohlins.![]()
Bodacious
If you are lookin' to run it off-trail most of the time I'd stay away from the 14" track as these things need all the square inches of footprint possible to keep them on top.
Charged RTX
I was thinking about running the 14 X 121 X 1 and some long studs on my RTX for lake running.
