1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
How funny would it look with a hartman 144 on my RTX with a 136 expert? Would it work and look okay? I can get a used Hartman 144 for my sled. I'm trying to get a visual of how much overhang there would be. I have also baught the Yamaha 136 large rear cooler that I need to fir into this thing. One good point of a longer tunnel ext. would be that the cooler would always have snow hitting it. Any suggestions?
-1CS
-1CS
LazyBastard
For the cooler, you will either have to modify the cooler to fit against the tunnel extension, or add drop down brackets for it to attach to. Aftermarket tunnel extensions are about 2 inches higher than OEM tunnel extensions.
For funny looking... Hartman 144" tunnel extension looks good (maybe even a little bit long) with 144" expertx. It'll look pretty silly with a 136. Why don't you get 144" rails to balance it all out?
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
LazyBastard said:For the cooler, you will either have to modify the cooler to fit against the tunnel extension, or add drop down brackets for it to attach to. Aftermarket tunnel extensions are about 2 inches higher than OEM tunnel extensions.
LB,
I really thought about the 144". I'm affraid it would wear me out in the trails after riding all day to manuver the sled threough the twisties. If the 136 goes well this season, I may in fact go to a 144 next year.
-1CS
Ratpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
I have a 144 expert under my 03 rx-1 and it rides no differnt than when it was a 136.I just put a hartman 151 extension on and that looks sweet
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
My 144 hartman extension is now mounted with the 136 expert. It doesn't look bad at all. I'll bet most peaple won't even be able to tell the differance. When my sled is all done, I'll post the pics in the garage section where some pics of my sled are already at.
-1CS
-1CS
