$16.00 clutch kit kicks butt.
Ted Jannetty
Waterbury Ct.
Website
www.jannettyracing.com
That's right fellas for $16.00 your sled will turn in to an animal.
I did mine and have 300 miles and it is Wicked.
All you non believers don't respond.
Get a Yamaha White secondary spring and install it on 3-3.
Tach goes to 10300 and climbs to 10600.
Enjoy.
Ted.
I haven't ran my RTX yet to see how she revs but my Attak was a raped ape hitting 11k with ease with stock clutching.
Enjoy.
Ted.
shhhh
The attaks come with the white secondary,but if you have cut your stock helix or are using an aftermarket helix cut for overdrive,it may coil bind,but it does run the rpms as it is the highest rate secondary that yammi lists.
Sled Dog said:
Would this same setup work on a 05 rx-1 shorty?
Yes it is a standard yammi part number white is a 1290 rate and pink is 1211 rate both stock springs and both are 5 bucks cheaper than the silver,because everyone wants the silver they can charge more lol,does it work any better yes and no actually the white has less coils than the standard pink but still more winds than the silver.
Be careful with this change. The white spring will bind with an aftermarket helix. I proved this at the track last year.
