Dr. FeeLGooD
The dealer who sold me my sled suggests the big engine warranty is a ploy to sell Yamaha oil. So anyway oil wetted parts would be the crank, cam and bearings? Is that pretty much it? Anybody hear of these types of failures yet? I have always used Yamalube but it is pricey.
JayM
- Oct 29, 2018
- Pickering, ON
- 2017 Sidewinder R-TX SE
I just figure I change the oil on my 20k machine once a season $100 CDN for the oil change kit is fine with me. I'm already saving a bunch doing the work myself anyways.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
I found 0 40 Mobil 1 full synthetic for 22 bucks a while back..(Walmart online only...free shipping to the store)Just checked - Crappy Tire has Mobile 1 on sale right now for $30.99 for 4.73 (5 qt) litre jug. Even comes in 0W-40.
5 qt. jug....check their site for rollback prices frequently! Got a set of Patagonia p metric 245 75 16''s for 90 each, next day they were 119 each!!
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
People showed a reduction in power when running the 40w oil vs the 30w. Dan posted a link showing the mobile 5w30 being superior to the 0w30. The difference between the 0 and the 5 is just the cold start viscosity. I've been running the 5w30 in all 5 yamaha sleds I do maintenance on for years with zero issues including starting at -20 degrees.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Here ya go gang...I run the Mobile 1 5w30 in most everything.....3rd best in this highly rated test below. Pennzoil Ultra is top dog, and great oil but typically M1 is cheaper at wallys.
https://ty4stroke.com/threads/whats-everyone-running-for-oil-with-tune.149935/#post-1386014
Mobil 1 5w30
5W30 Mobil 1, API SN synthetic = 105,875 psi (NOT Hi Mileage NOR Extended Perf)
zinc = 801 ppm
phos = 842 ppm
moly = 112 ppm
Here's the ranking list:
For those folks who are interested in this real world test data, below is the “Load Carrying Capacity/Film Strength” ranking list from all the real world motor oil “Wear Testing” I’ve performed so far on new oils, at a representative operational temperature of 230*F. The list includes modern API certified low zinc oils, traditional high zinc High Performance/Racing oils, Diesel oils, low zinc oils with zinc additives added in, and Break-In oils.
Lower ranked oils are not necessarily “bad”, they simply don’t provide as much wear protection capability as higher ranked oils. If you have been running a low ranked oil in your engine without issue, that doesn't mean you have a great oil, it only means that your engine's wear protection needs have not exceeded that oil's capability. And as long as your engine's needs don't exceed that oil's capability, you will never have a problem. But, if unexpected circumstances come up that make your engine's needs exceed that oil's capability, such as an overheating condition, an oiling condition, a loading condition, some parts heading south, or whatever, your engine can end up junk. But, if you'd been using an oil with a much higher capability, it could still provide enough extra protection to save your engine. So, each person has to decide for themselves, which motor oil provides the wear protection capability they are comfortable with, for any given engine build.
All oil bottles involved in the testing were thoroughly shaken before the samples were taken. This ensured that all the additive package components were distributed uniformly throughout all the oil in the bottle, and not settled to the bottom.
Test result differences between oils of less than 10% are not significant, and oils within that range can be considered approximately equivalent.
An oil's "wear protection" capability that was tested here, and an oil's "friction reduction" capability, are two entirely different things. While this test data provides excellent information about an oil's ability to prevent wear, it says nothing about an oil's ability to reduce friction. So, the data here will not provide any information regarding differences in HP potential.
The ppm quantities of zinc, phos, moly and in some cases titanium, shown in the list, are directly from the Lab Reports that came back from the Professional Lab “ALS Tribology” in Sparks, Nevada. Some oils have more zinc than phos, while other oils have more phos than zinc. It just depends on the particular oil’s formulation. Either way, the numbers are correct and are NOT typos.
NOTE: The higher the psi value, the BETTER the wear protection. And this applies to ANY engine, including High Performance flat tappet engines.
That psi value is determined by the testing "load" being applied (which of course, is the EXACT SAME for every oil tested), over the "area" of the wear scar that is created on the test specimen, as the test is being performed. So, the result is "pounds" of force being applied over the wear scar "area", which is in square inches. Or in other words, pounds per square inch, which of course is just shortened to "psi". The better an oil's wear protection capability, the smaller the wear scar will be on the test specimen, and the higher the resulting psi value will be.
Oil categories for gasoline engines:
• Over 90,000 psi = OUTSTANDING wear protection
• 75,000 to 90,000 psi = GOOD wear protection
• 60,000 to 75,000 psi = MODEST wear protection
• Below 60,000 psi = UNDESIRABLE wear protection
1. 5W30 Pennzoil Ultra, API SM synthetic = 115,612 psi
I have not been able to find this oil with the latest API SN certification. The bottle says, “No leading synthetic oil provides better wear protection”. For once, a product’s hype turns out to be true. And this oil provides MORE THAN TWICE as much wear protection as the lowest ranked oil on this list.
zinc = 806 ppm
phos = 812 ppm
moly = 66 ppm
2. 10W30 Lucas Racing Only synthetic = 106,505 psi
zinc = 2642 ppm
phos = 3489 ppm
moly = 1764 ppm
NOTE: This oil is suitable for short term racing use only, and is not suitable for street use.
3. 5W30 Mobil 1, API SN synthetic = 105,875 psi (NOT Hi Mileage NOR Extended Perf)
zinc = 801 ppm
phos = 842 ppm
moly = 112 ppm
4. 0W30 Amsoil Signature Series 25,000 miles, API SN synthetic = 105,008 psi
zinc = 824 ppm
phos = 960 ppm
moly = 161 ppm
5. 10W30 Valvoline NSL (Not Street Legal) Conventional Racing Oil = 103,846 psi
zinc = 1669 ppm
phos = 1518 ppm
moly = 784 ppm
6. 5W50 Motorcraft, API SN synthetic = 103,517 psi
zinc = 606 ppm
phos = 742 ppm
moly = 28 ppm
7. 10W30 Valvoline VR1 Conventional Racing Oil (silver bottle) = 103,505 psi
zinc = 1472 ppm
phos = 1544 ppm
moly = 3 ppm
8. 10W30 Valvoline VR1 Synthetic Racing Oil, API SL (black bottle) = 101,139 psi
zinc = 1180 ppm
phos = 1112 ppm
moly = 162 ppm
9. 5W30 Chevron Supreme, API SN conventional = 100,011 psi
This oil only cost $4.29 per quart at an Auto Parts Store when I bought it.
zinc = 1018 ppm
phos = 728 ppm
moly = 161 ppm
10. 5W20 Castrol Edge with Titanium, API SN synthetic = 99,983 psi
zinc = 1042 ppm
phos = 857 ppm
moly = 100 ppm
titanium = 49 ppm
11. 5W30 Pennzoil Platinum, API SN synthetic = 99,949 psi
zinc = TBD
phos = TBD
moly = TBD
12. 20W50 Castrol GTX ,API SN conventional = 96,514 psi
zinc = 610 ppm
phos = 754 ppm
moly = 94 ppm
13. 30 wt Red Line Race Oil synthetic = 96,470 psi
zinc = 2207 ppm
phos = 2052 ppm
moly = 1235 ppm
14. 0W20 Mobil 1 Advanced Fuel Economy, API SN synthetic = 96,364 psi
zinc = 742 ppm
phos = 677 ppm
moly = 81 ppm
15. 5W30 Quaker State Ultimate Durability, API SN synthetic = 95,920 psi
zinc = 877 ppm
phos = 921 ppm
moly = 72 ppm
16. 5W30 Castrol Edge with Titanium, API SN synthetic = 95,717 psi
zinc = 818 ppm
phos = 883 ppm
moly = 90 ppm
titanium = 44 ppm
17. 10W30 Joe Gibbs XP3 NASCAR Racing Oil synthetic = 95,543 psi
zinc = 743 ppm
phos = 802 ppm
moly = 1125 ppm
18. 5W20 Castrol GTX, API SN conventional = 95,543 psi
zinc = TBD
phos = TBD
moly = TBD
NOTE: Oil numbers 17 and 18 were tested weeks apart, but due to the similarities in their wear scar sizes, their averages ended up the same.
19. 5W30 Castrol GTX ,API SN conventional = 95,392 psi
zinc = 830 ppm
phos = 791 ppm
moly = 1 ppm
20. 10W30 Amsoil Z-Rod Oil synthetic = 95,360 psi
zinc = 1431 ppm
phos = 1441 ppm
moly = 52 ppm
21. 5W30 Havoline, API SN conventional = 95,098 psi
zinc = TBD
phos = TBD
moly = TBD
22. 5W30 Valvoline SynPower, API SN synthetic = 94,942 psi
zinc = 969 ppm
phos = 761 ppm
moly = 0 ppm
23. 5W30 Valvoline Premium Conventional, API SN = 94,744 psi
zinc = TBD
phos = TBD
moly = TBD
24. 5W20 Mobil 1, API SN synthetic = 94,663 psi
zinc = 764 ppm
phos = 698 ppm
moly = 76 ppm
25. 5W20 Valvoline SynPower, API SN synthetic = 94,460 psi
zinc = 1045 ppm
phos = 742 ppm
moly = 0 ppm
26. 5W30 Lucas, API SN conventional = 92,073 psi
zinc = 992 ppm
phos = 760 ppm
moly = 0 ppm
27. 5W30 O'Reilly (house brand), API SN conventional = 91,433 psi
This oil only cost $3.99 per quart at an Auto Parts Store when I bought it.
zinc = 863 ppm
phos = 816 ppm
moly = 0 ppm
28. 5W30 Maxima RS530 Synthetic Racing Oil = 91,162 psi
zinc = 2162 ppm
phos = 2294 ppm
moly = 181 ppm
29. 5W30 Red Line, API SN synthetic = 91,028 psi
zinc = TBD
phos = TBD
moly = TBD
30. 5W20 Royal Purple API SN synthetic = 90,434 psi
zinc = 964 ppm
phos = 892 ppm
moly = 0 ppm
31. 10W30 Quaker State Defy, API SL semi-synthetic = 90,226 psi
zinc = 1221 ppm
phos = 955 ppm
moly = 99 ppm
32. 10W60 Castrol TWS Motorsport, API SJ conventional = 90,163 psi
This oil is manufactured in Europe and is sold in the US for BMW models M3, M5, M6, Z4M, and Z8.
zinc = TBD
phos = TBD
moly = TBD
33. 5W20 Valvoline Premium Conventional, API SN = 90,144 psi
zinc = TBD
phos = TBD
moly = TBD
34. 5W30 Havoline, API SN synthetic = 89,406 psi
zinc = TBD
phos = TBD
moly = TBD
35. 30 wt Castrol Heavy Duty, API SM conventional = 88,089 psi
zinc = 907 ppm
phos = 829 ppm
moly = 56 ppm
36. 20W50 LAT Synthetic Racing Oil, API SM = 87,930 psi
zinc = TBD
phos = TBD
moly = TBD
37. 5W30 Valvoline Nextgen 50% Recycled Oil, API SN conventional = 87,563 psi
zinc = 947 ppm
phos = 778 ppm
moly = 0 ppm
38. 10W30 Joe Gibbs HR4 Hotrod Oil synthetic = 86,270 psi
zinc = 1247 ppm
phos = 1137 ppm
moly = 24 ppm
39. 5W20 Pennzoil Ultra, API SM synthetic = 86,034 psi
zinc = TBD
phos = TBD
moly = TBD
40. 15W40 RED LINE Diesel Oil synthetic, API CJ-4/CI-4 PLUS/CI-4/CF/CH-4/CF-4/SM/SL/SH/EO-O = 85,663 psi
zinc = 1615 ppm
phos = 1551 ppm
moly = 173 ppm
41. 5W30 Castrol Edge w/Syntec, API SN (formerly Castrol Syntec) black bottle, synthetic = 85,179 psi
zinc = TBD
phos = TBD
moly = TBD
42. 5W30 Royal Purple API SN synthetic = 84,009 psi
zinc = 942 ppm
phos = 817 ppm
moly = 0 ppm
43. 20W50 Royal Purple API SN synthetic = 83,487 psi
zinc = 588 ppm
phos = 697 ppm
moly = 0 ppm
44. 20W50 Kendall GT-1 High Performance with liquid titanium, API SN conventional = 83,365 psi
zinc = 991 ppm
phos = 1253 ppm
moly = 57 ppm
titanium = 84 ppm
45. 5W30 Mobil 1 Extended Performance 15,000 mile, API SN synthetic = 83,263 psi
zinc = 890 ppm
phos = 819 ppm
moly = 104 ppm
46. 0W20 Castrol Edge with Titanium, API SN synthetic = 82,867 psi
zinc = TBD
phos = TBD
moly = TBD
47. 5W30 LAT Synthetic Racing Oil, API SM = 81,800 psi
zinc = 1784 ppm
phos = 1539 ppm
moly = 598 ppm
48. 5W30 Peak, API SN synthetic = 80,716 psi
zinc = TBD
phos = TBD
moly = TBD
49. 5W30 Edelbrock "Cat-Safe", API SM synthetic = 78,609 psi
This oil is made for Edelbrock by Torco
zinc = 924 ppm
phos = 659 ppm
moly = 28 ppm
50. 15W40 ROYAL PURPLE Diesel Oil synthetic, API CJ-4 /SM, CI-4 PLUS, CH-4, CI-4 = 76,997 psi
zinc = TBD
phos = TBD
moly = TBD
51. 5W30 Pennzoil, API SN yellow bottle, conventional = 76,989 psi
zinc = TBD
phos = TBD
moly = TBD
52. 10W40 Chevron Supreme, API SN conventional = 76,806 psi
zinc = TBD
phos = TBD
moly = TBD
53. 5W30 Lucas API SM synthetic = 76,584 psi
zinc = 1134 ppm
phos = 666 ppm
moly = 0 ppm
54. 5W30 GM's AC Delco dexos 1 API SN semi-synthetic = 76,501 psi
zinc = 878 ppm
phos = 758 ppm
moly = 72 ppm
55. 5W50 Castrol Edge with Syntec API SN, synthetic, formerly Castrol Syntec, black bottle = 75,409 psi
zinc = 1252 ppm
phos = 1197 ppm
moly = 71 ppm
56. 5W30 Royal Purple XPR (Extreme Performance Racing) synthetic = 74,860 psi
zinc = 1421 ppm
phos = 1338 ppm
moly = 204 ppm
NOTE: This particular bottle of oil was just opened, but was out of a 3 ½ year old case.
57. 5W40 MOBIL 1 TURBO DIESEL TRUCK synthetic, API CJ-4, CI-4 Plus, CI-4, CH-4 and ACEA E7 = 74,312 psi
zinc = 1211 ppm
phos = 1168 ppm
moly = 2 ppm
58. 5W30 Peak, API SN conventional = 73,690 psi
zinc = TBD
phos = TBD
moly = TBD
59. 15W40 CHEVRON DELO 400LE Diesel Oil, conventional, API CJ-4, CI-4 Plus, CH-4, CF-4,CF/SM, = 73,520 psi
zinc = 1519 ppm
phos = 1139 ppm
moly = 80 ppm
60. 15W40 MOBIL DELVAC 1300 SUPER Diesel Oil conventional, API CJ-4, CI-4 Plus, CI-4, CH-4/SM, SL = 73,300 psi
zinc = 1297 ppm
phos = 1944 ppm
moly = 46 ppm
61. 15W40 Farm Rated Heavy Duty Performance Diesel Oil conventional CI-4, CH-4, CG-4, CF/SL, SJ = 73,176 psi
zinc = 1325ppm
phos = 1234 ppm
moly = 2 ppm
62. 15W40 SHELL ROTELLA T Diesel Oil conventional, API CJ-4, CI-4 Plus, CH-4, CF-4,CF/SM = 72,022 psi
zinc = 1454 ppm
phos = 1062 ppm
moly = 0 ppm
63. Brad Penn, Penn Grade 1 Nitro 70 Racing Oil semi-synthetic = 72,003 psi
zinc = TBD
phos = TBD
moly = TBD
64. 0W30 Brad Penn, Penn Grade 1 semi-synthetic = 71,377 psi
zinc = 1621 ppm
phos = 1437 ppm
moly = 0 ppm
65. 15W40 “OLD” SHELL ROTELLA T Diesel Oil conventional, API CI-4 PLUS, CI-4, CH-4,CG-4,CF-4,CF,SL, SJ, SH = 71,214 psi
zinc = 1171 ppm
phos = 1186 ppm
moly = 0 ppm
66. 10W30 Brad Penn, Penn Grade 1 semi-synthetic = 71,206 psi
zinc = 1557 ppm
phos = 1651 ppm
moly = 3 ppm
67. 15W40 VALVOLINE PREMIUM BLUE HEAVY DUTY DIESEL Oil conventional, API CJ-4, CI-4 Plus, CI-4, CH-4, CG-4, CF-4, CF/SM = 70,869 psi
zinc = TBD
phos = TBD
moly = TBD
68. 15W50 Mobil 1, API SN synthetic = 70,235 psi
zinc = 1,133 ppm
phos = 1,168 ppm
moly = 83 ppm
69. 5W40 CHEVRON DELO 400LE Diesel Oil synthetic, API CJ-4, CI-4 Plus, CI-4, SL, SM = 69,631 psi
zinc = TBD
phos = TBD
moly = TBD
70. 30wt Edelbrock Break-In Oil conventional = 69,160 psi
zinc = 1545 ppm
phos = 1465 ppm
moly = 4 ppm
71. 5W30 Motorcraft, API SN synthetic = 68,782 psi
zinc = 796 ppm
phos = 830 ppm
moly = 75 ppm
72. 10W40 Edelbrock synthetic = 68,603 psi
zinc = 1193 ppm
phos = 1146 ppm
moly = 121 ppm
This oil is manufactured for Edelbrock by Torco.
73. 5W40 SHELL ROTELLA T6 Diesel Oil synthetic, API CJ-4, CI-4 Plus, CI-4, CH-4, SM, SL = 67,804 psi
zinc = TBD
phos = TBD
moly = TBD
74. 15W40 LUCAS MAGNUM Diesel Oil, conventional, API CI-4,CH-4, CG-4, CF-4, CF/SL = 66,476 psi
zinc = 1441 ppm
phos = 1234 ppm
moly = 76 ppm
75. 15W40 CASTROL GTX DIESEL Oil conventional, API CJ-4, CI-4 Plus, CI-4, CH-4, CG-4, CF-4/SN = 66,323 psi
zinc = TBD
phos = TBD
moly = TBD
76. 10W30 Royal Purple HPS (High Performance Street) synthetic = 66,211 psi
zinc = 1774 ppm
phos = 1347 ppm
moly = 189 ppm
77. 10W40 Valvoline 4 Stroke Motorcycle Oil, API SJ conventional = 65,553 psi
zinc = 1154 ppm
phos = 1075 ppm
moly = 0 ppm
78. 5W30 Klotz Estorlin Racing Oil, API SL synthetic = 64,175 psi
zinc = 1765 ppm
phos = 2468 ppm
moly = 339 ppm
79. “ZDDPlus” added to Royal Purple 20W50, API SN, synthetic = 63,595 psi
zinc = 2436 ppm (up 1848 ppm)
phos = 2053 ppm (up 1356 ppm)
moly = 2 ppm (up 2 ppm)
The amount of ZDDPlus added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 24% LOWER than this oil had BEFORE the ZDDPlus was added to it. Most major Oil Companies say to NEVER add anything to their oils, because adding anything will upset the carefully balanced additive package, and ruin the oil’s chemical composition. And that is precisely what we see here. Adding ZDDPlus SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
80. Royal Purple 10W30 Break-In Oil conventional = 62,931 psi
zinc = 1170 ppm
phos = 1039 ppm
moly = 0 ppm
81. 10W30 Lucas Hot Rod & Classic Hi-Performance Oil, conventional = 62,538 psi
zinc = 2116 ppm
phos = 1855 ppm
moly = 871 ppm
82. 0W20 Klotz Estorlin Racing Oil, API SL synthetic = 60,941 psi
zinc = TBD
phos = TBD
moly = TBD
83. 10W30 Comp Cams Muscle Car & Street Rod Oil, synthetic blend = 60,413 psi
zinc = 1673 ppm
phos = 1114 ppm
moly = 67 ppm
This oil is manufactured for Comp Cams by Endure.
84. 10W40 Torco TR-1 Racing Oil with MPZ conventional = 59,905 psi
zinc = 1456 ppm
phos = 1150 ppm
moly = 227 ppm
85. 10W40 Summit Racing Premium Racing Oil, API SL = 59,483 psi
This oil is made for Summit by I.L.C.
zinc = TBD
phos = TBD
moly = TBD
86. 10W40 Edelbrock conventional = 59,120 psi
zinc = TBD
phos = TBD
moly = TBD
87. 0W20 LAT Synthetic Racing Oil, API SM = 57,228 psi
zinc = TBD
phos = TBD
moly = TBD
88. “ZDDPlus” added to O’Reilly (house brand) 5W30, API SN, conventional = 56,728 psi
zinc = 2711 ppm (up 1848 ppm)
phos = 2172 ppm (up 1356 ppm)
The amount of ZDDPlus added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 38% LOWER than this oil had BEFORE the ZDDPlus was added to it. Adding ZDDPlus SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
89. “ZDDPlus” added to Motorcraft 5W30, API SN, synthetic = 56,243 psi
zinc = 2955 ppm (up 1848 ppm)
phos = 2114 ppm (up 1356 ppm)
moly = 76 ppm (up 2 ppm)
The amount of ZDDPlus added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 12% LOWER than this oil had BEFORE the ZDDPlus was added to it. Adding ZDDPlus SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
90. “Edelbrock Zinc Additive” added to Royal Purple 5W30, API SN, synthetic = 54,044 psi
zinc = 1515 ppm (up 573 ppm)
phos = 1334 ppm (up 517 ppm)
moly = 15 ppm (up 15 ppm)
The amount of Edelbrock Zinc Additive added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was a whopping 36% LOWER than this oil had BEFORE the Edelbrock Zinc Additive was added to it. Adding Edelbrock Zinc Additive SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
91. 10W30 Comp Cams Break-In Oil conventional = 51,749 psi
zinc = 3004 ppm
phos = 2613 ppm
moly = 180 ppm
92. “Edelbrock Zinc Additive” added to Lucas 5W30, API SN, conventional = 51,545 psi
zinc = 1565 ppm (up 573 ppm)
phos = 1277 ppm (up 517 ppm)
The amount of Edelbrock Zinc Additive added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was a “breath taking” 44% LOWER than this oil had BEFORE the Edelbrock Zinc Additive was added to it. Adding Edelbrock Zinc Additive SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
93. “Edelbrock Zinc Additive” added to Motorcraft 5W30, API SN, synthetic = 50,202 psi
zinc = 1680 ppm (up 573 ppm)
phos = 1275 ppm (up 517 ppm)
moly = 89 ppm (up 15 ppm)
The amount of Edelbrock Zinc Additive added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 22% LOWER than this oil had BEFORE the Edelbrock Zinc Additive was added to it. Adding Edelbrock Zinc Additive SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
94. 30wt Lucas Break-In Oil conventional = 49,455 psi
zinc = 4483 ppm
phos = 3660 ppm
moly = 3 ppm
At the end of the day, it is not my goal to convince anyone of anything. I’m simply sharing valuable real world test data for folks to consider. Everyone can obviously decide for themselves if they want to embrace this data and make use of it, or if they simply want to ignore it.
540 RAT
Member SAE (Society of Automotive Engineers)
Mobil 1 5w30
zinc = 801 ppm
phos = 842 ppm
moly = 112 ppm
zinc = 806 ppm
phos = 812 ppm
moly = 66 ppm
zinc = 2642 ppm
phos = 3489 ppm
moly = 1764 ppm
zinc = 801 ppm
phos = 842 ppm
moly = 112 ppm
zinc = 824 ppm
phos = 960 ppm
moly = 161 ppm
zinc = 1669 ppm
phos = 1518 ppm
moly = 784 ppm
zinc = 606 ppm
phos = 742 ppm
moly = 28 ppm
zinc = 1472 ppm
phos = 1544 ppm
moly = 3 ppm
zinc = 1180 ppm
phos = 1112 ppm
moly = 162 ppm
zinc = 1018 ppm
phos = 728 ppm
moly = 161 ppm
zinc = 1042 ppm
phos = 857 ppm
moly = 100 ppm
titanium = 49 ppm
zinc = TBD
phos = TBD
moly = TBD
zinc = 610 ppm
phos = 754 ppm
moly = 94 ppm
zinc = 2207 ppm
phos = 2052 ppm
moly = 1235 ppm
zinc = 742 ppm
phos = 677 ppm
moly = 81 ppm
zinc = 877 ppm
phos = 921 ppm
moly = 72 ppm
zinc = 818 ppm
phos = 883 ppm
moly = 90 ppm
titanium = 44 ppm
zinc = 743 ppm
phos = 802 ppm
moly = 1125 ppm
zinc = TBD
phos = TBD
moly = TBD
zinc = 830 ppm
phos = 791 ppm
moly = 1 ppm
zinc = 1431 ppm
phos = 1441 ppm
moly = 52 ppm
zinc = TBD
phos = TBD
moly = TBD
zinc = 969 ppm
phos = 761 ppm
moly = 0 ppm
zinc = TBD
phos = TBD
moly = TBD
zinc = 764 ppm
phos = 698 ppm
moly = 76 ppm
zinc = 1045 ppm
phos = 742 ppm
moly = 0 ppm
zinc = 992 ppm
phos = 760 ppm
moly = 0 ppm
zinc = 863 ppm
phos = 816 ppm
moly = 0 ppm
zinc = 2162 ppm
phos = 2294 ppm
moly = 181 ppm
zinc = TBD
phos = TBD
moly = TBD
zinc = 964 ppm
phos = 892 ppm
moly = 0 ppm
zinc = 1221 ppm
phos = 955 ppm
moly = 99 ppm
zinc = TBD
phos = TBD
moly = TBD
zinc = TBD
phos = TBD
moly = TBD
zinc = TBD
phos = TBD
moly = TBD
zinc = 907 ppm
phos = 829 ppm
moly = 56 ppm
zinc = TBD
phos = TBD
moly = TBD
zinc = 947 ppm
phos = 778 ppm
moly = 0 ppm
zinc = 1247 ppm
phos = 1137 ppm
moly = 24 ppm
zinc = TBD
phos = TBD
moly = TBD
zinc = 1615 ppm
phos = 1551 ppm
moly = 173 ppm
zinc = TBD
phos = TBD
moly = TBD
zinc = 942 ppm
phos = 817 ppm
moly = 0 ppm
zinc = 588 ppm
phos = 697 ppm
moly = 0 ppm
zinc = 991 ppm
phos = 1253 ppm
moly = 57 ppm
titanium = 84 ppm
zinc = 890 ppm
phos = 819 ppm
moly = 104 ppm
zinc = TBD
phos = TBD
moly = TBD
zinc = 1784 ppm
phos = 1539 ppm
moly = 598 ppm
zinc = TBD
phos = TBD
moly = TBD
zinc = 924 ppm
phos = 659 ppm
moly = 28 ppm
zinc = TBD
phos = TBD
moly = TBD
zinc = TBD
phos = TBD
moly = TBD
zinc = TBD
phos = TBD
moly = TBD
zinc = 1134 ppm
phos = 666 ppm
moly = 0 ppm
zinc = 878 ppm
phos = 758 ppm
moly = 72 ppm
zinc = 1252 ppm
phos = 1197 ppm
moly = 71 ppm
zinc = 1421 ppm
phos = 1338 ppm
moly = 204 ppm
zinc = 1211 ppm
phos = 1168 ppm
moly = 2 ppm
zinc = TBD
phos = TBD
moly = TBD
zinc = 1519 ppm
phos = 1139 ppm
moly = 80 ppm
zinc = 1297 ppm
phos = 1944 ppm
moly = 46 ppm
zinc = 1325ppm
phos = 1234 ppm
moly = 2 ppm
zinc = 1454 ppm
phos = 1062 ppm
moly = 0 ppm
zinc = TBD
phos = TBD
moly = TBD
zinc = 1621 ppm
phos = 1437 ppm
moly = 0 ppm
zinc = 1171 ppm
phos = 1186 ppm
moly = 0 ppm
zinc = 1557 ppm
phos = 1651 ppm
moly = 3 ppm
zinc = TBD
phos = TBD
moly = TBD
zinc = 1,133 ppm
phos = 1,168 ppm
moly = 83 ppm
zinc = TBD
phos = TBD
moly = TBD
zinc = 1545 ppm
phos = 1465 ppm
moly = 4 ppm
zinc = 796 ppm
phos = 830 ppm
moly = 75 ppm
zinc = 1193 ppm
phos = 1146 ppm
moly = 121 ppm
zinc = TBD
phos = TBD
moly = TBD
zinc = 1441 ppm
phos = 1234 ppm
moly = 76 ppm
zinc = TBD
phos = TBD
moly = TBD
zinc = 1774 ppm
phos = 1347 ppm
moly = 189 ppm
zinc = 1154 ppm
phos = 1075 ppm
moly = 0 ppm
zinc = 1765 ppm
phos = 2468 ppm
moly = 339 ppm
zinc = 1170 ppm
phos = 1039 ppm
moly = 0 ppm
zinc = 2116 ppm
phos = 1855 ppm
moly = 871 ppm
zinc = TBD
phos = TBD
moly = TBD
zinc = 1673 ppm
phos = 1114 ppm
moly = 67 ppm
zinc = 1456 ppm
phos = 1150 ppm
moly = 227 ppm
zinc = TBD
phos = TBD
moly = TBD
zinc = TBD
phos = TBD
moly = TBD
zinc = TBD
phos = TBD
moly = TBD
zinc = 3004 ppm
phos = 2613 ppm
moly = 180 ppm
zinc = 4483 ppm
phos = 3660 ppm
moly = 3 ppm
540 RAT
JayM
- Oct 29, 2018
- Pickering, ON
Great info, do we know where Yamalube sits in that test?
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
Wow, great info, but where is yamalube?
I didn't read all 94, since all those oils I'm sure will work fine.
Personally, Mobil1 in all my gas stuff including supercharged mustang, and rotella t synthetic in all the diesels. Like forever...zero issues. Actually, the Perkins calls for rotella.
JayM
- Oct 29, 2018
- Pickering, ON
I just put in the 0W40 Full Synthetic Yamalube at my first oil change as that is what the dealer suggested. If I can gain some performance with a lighter weight oil I may change it up, at least its easy wih removable side panel
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
In my case, one less cheeseburger will make a bigger performance difference than oil weight! lol!I just put in the 0W40 Full Synthetic Yamalube at my first oil change as that is what the dealer suggested. If I can gain some performance with a lighter weight oil I may change it up, at least its easy wih removable side panel![]()
RAMSOMAIR
Would 0w20 be too light? I have a ton of Mobil 1 kicking around from the wife’s Venza.
