1988 Moto 4 with weak spark
bija
Eagle, WI
LOCATION
Eagle, WI
I have got this machine to fix up a 1988 Moto 4 225cc, I have fixed the electric start. it seems to have good compression, I sprayed some starting fluid in the cylinder and tried to start it. It would not even sputter, I took the plug out (it is new) and set it against the cylinder and tried again, there was spark, but it didn't seem very strong. What would you guys suggest to try, coil? CDI? Thanks for your help
try changing the oil. if someone flooded it really bad it will never start. had this happen at -40c with a couple of p/u once.
