2 Speed weights clutching setup
BADSLED
Syracuse, NY
2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
I have a set of Heelclicker 2 speed weights weights I would like to try out on Nytro XTX. Looking for baseline recommndations for a starting point on tuning hardware placement and helix angle.
Try this
black hc primary spring
1 bolt 2 washers in heel
rest of weight empty.
45 or 47 helix will give better aceleration.
Have you run these with the 14.5mm rollers? I noticed the weights are 2mm shorter then stock weights.
I thought I remember you running the Rat weights? What's up?
I did try the Super Rats, but wanted to try 2 speed setup before the season is over.
He sold them to me, lol...........
if you want a holeshot and to pull ....you know what I said....
What is the difference between the updated series series of 2 speed weights vs. original?
original 40-10's were powder metal with an aluminum "hammer"...
the new is all billet steel and therefore...the hammer is 20 grams vs 10 grams...
the newer has a slightly less agressive profile...
Thanks, SJ.
the original 4 stroke 2 speeds were 20/40. When they shaved 2 grams off the body of the main weight they worked a lot better to make them into 20/38.
yes turk you are talking of the second version basically while he was switching over to the billet steel....
the originals had a 10 gram aluminum hammer....
turk p.m. me when you get a chance on that update
