I keep blowing the 20 amp mini fuse. I just installed the MCX 180 kit, and I can ride for about 20 miles and then it goes. Replace it and keep going. I am sure its a wire rubbing, but not sure where to start.
680
680
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Look behind the primary clutch where the motor mount bolt goes from the frame to the motor. The FX Nytro models are known to rub the harness through on a little "peg" that sticks out of part of the motor mount on the motor.
Thanks Allen, but everything looked fine. I had a couple wires pulled out of my Roll over valve, Fixed up now!
680
680
Nytroglycerin
do you have an OFT teather kit?? mine is causing the ign fuse to blow.
I blew one on Sun while I was working on my sled I think I hit something I will check it out tomorrow and when I went to unload my sled I had nothing I will be checking it all out tomorrow but Im assuming I blew another one while it was on the trailer? I'll post what I find.
