beeze455
- Nov 23, 2010
- Bowdoinham, ME
- www.gopherdesign.com
So I want to buy the skinz boards, but did not want to want to spend the money just yet. I figured the skinz boards would require me to cut the board either way, so I decided to drill some holes.
Some before pics:
On the very backside of the tunnel start measuring. i marked lins at 2 4 6 8.
Measure the middle point
Tap
Use WD-40 or a cutting oil. Do this and run your drill slow. it will cost you more in bits.
Drill pilot hole
Drill away
Find spots you like, mark and drill
All Done
Some before pics:
Tap
Drill pilot hole
Drill away
All Done
Nikolai
Looks good. I would recommend getting a dimple die and flaring the holes, it will strengthen the surrounding area of the running board.
NFLD-Nytro
Not bad. Like you, I'd love to have the Skinz boards, but I don't think I could bring myself to hack off my running boards.
beeze455
- Nov 23, 2010
- Bowdoinham, ME
Def wanna get a dimple die and maybe put more holes to the left.
beeze455
- Nov 23, 2010
- Bowdoinham, ME
Just tested them out and wow well worth the work.
Whats the benefit?
I would add that you should make up a shape out of thin plasic or tin that looks more like the factory shapes. lay it over the holes you made and trace it out. Then with a die grinder or nibler, then a file, make the new shape. It would look more factory.
great idea though non the less
beeze455
- Nov 23, 2010
- Bowdoinham, ME
yea, I may do something this summer to clean it up a bit. I was testing to see how much of a difference it made.
