jpilk99
- Dec 11, 2021
- Bolton, MA
- 2006 Yamaha Apex GT
Hi all,
I have a 2000 Yahama Phazer 500 that doesn't want to throttle up, smoothly/if at all. It does start pretty normally and idle well.
After removing the mouse debris (sunflower seed shells) from the airbox and carb inlet, I took the carbs off and cleaned them. Removed all jets, used my "carb cleaning" wires etc. and carb cleaner spray (after removing any rubber bits). Put all back together and was thrilled to get it running. But I can't get it to throttle-up smoothly. Sounds like it's not getting enough fuel, quickly enough. Thanks for any suggestions - Here's a video & audio:
jpilk99
- Dec 11, 2021
- Bolton, MA
Here's a better audio one:
get the air box back on it and try again. these sleds do not like running without the stock air box. causes all kinds of issues.
also pull the fuel filter out the fill hole on the gas tank and make sure it has not fallen apart or is full of crud.
jpilk99
- Dec 11, 2021
- Bolton, MA
THANK YOU!!! I wondered, (after having the carbs off for the 7th time), if the airbox being out would make a difference. I'll put it back and go after the fuel filter!get the air box back on it and try again. these sleds do not like running without the stock air box. causes all kinds of issues.
Do you know if there's a Mikuni rebuild kit for these carbs, (Mikuni B38-32)? I noticed that the pilot jet on one carb had a bigger diameter hole running the length of the jet vs. the other one. I know the mains are different. I assume the larger port jets should be on the PTO side?? I might be better off just getting a kit with the exact spec'd parts... if there is such a kit. I ain't finding one.
Thank you,
Jay
jpilk99
- Dec 11, 2021
- Bolton, MA
Hey there. I just fished around down in the fuel tank, (through the fill hole), and I can't find any filter. I checked the manual and it just says to "check the fuel filter" but doesn't say how/where. I've read on older Phazers that you have to pull the seat to access?? That doesn't seem to make sense if it's IN the tank. Assuming it would be toward the forward/left (or PTO) side of tank since that's where the fuel line comes through to the fuel pump. Any help in getting to the fuel filter is greatly appreciated.get the air box back on it and try again. these sleds do not like running without the stock air box. causes all kinds of issues.
Thank you.
the filter moves around on a hose in the tank and normal procedure is to use a coat hanger to reach down in and hook the hose to bring the filter to the filler neck.
RobX-1
- Coldwater, OH
