rx1 man 04
- Oct 4, 2007
- ottawa
- 2007 Yamaha apex gt and 2012 Yamaha apex xtx
my buddies sled wont start after sitting all summer. no spark to any of the spark plugs 700 triple. took the starter recoil housing cover off, cleaned all the flywheel cover and pick up coil. check for voltage coming out of the pins, nothing thinking the stator is defective, any ideas, check the on /off kill switch working ok, any ideas or suggestions? how do you check the stator, what are the ohm readings etc. We checked to see if any cables had been damaged by mice, did not see any damage, the sled was working fine when he put it away last spring. sled is a 2001 Yamaha venture 700 deluxe two up.
