2003 Rx1 A arm bushings?
NorthernMainer
Caribou Maine
2003 Yamaha Rx1
So it seems that they dont make the upper A arm bushings for the 2003 Rx1. I find kits for 2004, and up but not the 2003. I know theres a difference in the A arms themselves between years. Can you put the 2004 upper A arms on the 2003 so I can use a 2004 bushing kit? Thank you in advance!
I assume you are talking about the oilite bushings. No they don't make them for the 03. At least not when I was looking for them. And no the 04 won't fit. I went through this last year. I checked out what had to be done to make the 04 ones work and it included complete upper arms, bolts. Not worth it for me. I bought the nylatron kit from pioneer performance, but I guess that doesn't help you now that they are no longer in business but I'm not sure if someone else is making them.
Well if it's just upper arms and bolts I'll go ahead, and swap it. That's easy enough for me.
Does anyone know if someone other than Pioneer Performance is now making the nylatron bushings since Pioneer has closed shop?
