I am putting a 2005 Crossfire skid (15x136) in my 2004 Warrior and wanted to see if anyone here knows where the mounting hole locations should be? Thanks for your reply!
grader
you will have to take some key measurements from the crossfire to make it work properly in your sled. eg. distance of front mount holes back from drive axel, as well as distance down from inside top of tunnel. rear mounting holes also from top and back or from front holes. when measuring inside rx tunnel, use the bottom of the tunnel protectors as the inside tunnel measurement.
