2005 RS Venture-Cannot Find This Part Number-Please Help
Glock30
All,
I cannot find, anywhere in the fiche, the black plastic part that the gage cluster fits into.
Not anything on the guage cluster (meter) but the bezel that faces the driver that the meter sits in.
Any help would be greatly appreciated.
Glock
Are you refering to the plastic housing that the guage is in? That will be under "instrument" in the fiche. If you are refering to the dash panel that the guage assembly is mounted to, then you should look under "shroud" in the fiche. If you require the dash panel they are available at Royal Distributing for lower cost. Hope this helps.
