yamahaconvert
- Dec 25, 2012
Hey everyone... I just joined as i picked up a 2005 RX warrior and i noticed on the first ride that the clutch engagement seem high and jerky or ruff, also i could smell the drive belt burn a little on slower take offs. If I tried a slow smooth take off it kinda surged and i could smell the belt slipping. if a faster squeeze on the throttle it grabbed hard and takes off. but I want a smoother transition.I trail ride mostly and weigh in at 250 with gear and am looking for a fix.
I have read that putting in the 14.5 rollers and ypy spring will help with engagement and make it smoother? should I look for other normal clutch maintenance things first?
Also where could I but the 14.5 rollers and the ypy spring?
Thanks in advance
Thanks in advance
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
I am wondering about the exact same thing. My dads sled behaves the same way.
Its also a 05 RX1.
Its also a 05 RX1.
jsjk-4-stroke
if i were you guys i would start with stock parts in the clutch & secondary , & work from there , you could have diff parts in ther that don,t match , stock is smooth.
with your belt their is adjustment behind secondary , if new belt you may need to adjust it.
clean the clutches 1st as belt dust will cause them to bind. some guys swear by the dishwasher but i usually clean mine with a shop towel and a blow gun.
tedgoesfast
service clutches pull cover of front and ispect and clean also inspect rear for buttons broke it will let belt go to low and it start out in to high ratio
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Mine shifts smooth with 18,000 miles on it. All stock! I blow out the clutches every 500 miles and clean the clutches every year.
