polarisconvert
- Mar 22, 2006
- Corunna, MI
- 2005 Yamaha RX1
Ted Jennety Clutching, jetting, air box mod.
Arctic Cat Z1 Turbo 128" Rear Suspension
128" Hacksaw 1" track.
Heated seat
I pulled my chain case apart a couple months age to istall a cat skid and new track. I was putting it back together today and have a spacer I don't remember where it goes. It has a oring on the inside ofthe spacer, and you can see that it sets iinside a seal on the outside diameter. It fits perfectly where #9 spacer goes in the diagram, but the correct specer has a set screw.
Here is a pic.
Here is a pic.
AIRWOLF
Guest
- Oct 1, 2004
- New York
- www.sledpartsgarage.com
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
That collar goes onto end of driveshaft. It typically stays put on the shaft when you remove the drivers. The lower chaincase seal seats up on that spacer.
polarisconvert
- Mar 22, 2006
- Corunna, MI
- 2005 Yamaha RX1
Heated seat
So the drivers have to come back out to install?
AIRWOLF
Guest
- Oct 1, 2004
- New York
No just the chaincase
polarisconvert
- Mar 22, 2006
- Corunna, MI
- 2005 Yamaha RX1
Heated seat
Ok thanks for the help guys. Makes perfect sense.
blkhwkbob
I'm not sure where you guys are getting your numbers, but it is the shaft seal on the back side of the chain case. There is one on the jack shaft and one on the drive shaft. In the drawings, they show the o-ring as a separate part. Use the Yamaha Parts finder up on top of the page.
polarisconvert
- Mar 22, 2006
- Corunna, MI
- 2005 Yamaha RX1
Heated seat
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Glad to help!
xj4me
- Oct 17, 2012
- Cadott Wi
- 2006 attack
I lost a brand new bearing last year due to that spacer falling in my oil catch and not reinstalling it. Great catch!
polarisconvert
- Mar 22, 2006
- Corunna, MI
- 2005 Yamaha RX1
Heated seat
I did not see it fall off and it seems to be pretty tight with the oring so not sure how it happened.
stomper
YepI'm not sure where you guys are getting your numbers, but it is the shaft seal on the back side of the chain case. There is one on the jack shaft and one on the drive shaft. In the drawings, they show the o-ring as a separate part. Use the Yamaha Parts finder up on top of the page.
