tedgoesfast
i have a 05 rx1 does anyone have some good clutch combos to make them work the way they should my buddies 2007 sdi 600 is running a lenth behind me allthow he has spent big moniy on a team tied secondary and a thunder shift kit .there must be betters weight and spring setups or are they just a dog thanks
I've got a set of drag n flys on mine and like them but ulmer has good set up to also you can do an air box mod also hang in there people can help you set it up right and you'll be way ahead soon
tedgoesfast
what is the air box mod
tedgoesfast said:what is the air box mod
Look under mods section and look for sled dogs air box mod I just looked its like the fourth one down its good cheap HP if you get a set of drag n flys ill tell you what I'm running but your going to need studs because it launchs hard other wise ask Turk he helped me dial in mine
tedgoesfast
what rpm does it have to turn i got a dyno sheet of ty when you look at pto shaft hp it should at least turn 10500 iam only turning 10100 to 10200
normal with stock clutching.
i love my set-up from ulmer. really woke the sled up.
Pm sent
Bigblue1
- Nov 29, 2007
- NY
- Sidewinder RTX-LE
Apex SE
Just did 104mph (GPS) in a 1/4 mile yesterday on very slippery conditions...powder snow on hard ice with just an ice ripper track. About 30 sleds there and the only ones faster were two 2011 XP E-Techs that were studded. One did 106mph, the other, a long tract, went 111. There was also a worked and studded 1000 Cat Sno Pro that did 109. My sled, although very well maintained is going on its 7th winter with about 9,000 miles. Not bad for old school. Plus I am 6'3" 280lbs. It has a Bender Clutch kit, K&N intake kit and 165 jets. Clutch kit is a must on these as they are just mush from the factory. Just the clutch will put a big smile on your face. Ulmer has great stuff too. Hope it helps
factorystock70
Rx1 wheel updates
Check out www.schmidtbrosmotorsports.com They do the cold air box mods and rejetting. I have an 05' Rx1 with about 2300 miles on it. I didnt have the air box mods done but I had them install about 4-6 more boggie wheels underneath the suspension where they need to be. 2 in the front arch rail. 1 to complete the 4 in the back axle. 1 on each side in the rear 2 inches ahead of the back axle and a few in between. Theese wheels will cause you to do a lil re clutching which he does before you get it back. Your not dragging your slides anymore, everything is free'd up and that alone is about 5 hp. Im throughly impressed.
tedgoesfast
i put all polaris wheels in mine and the rear axle i put kimpex the kimpex are .25 of an inch bigger this has stopped my slider from burning and alot less rolling resistance
tedgoesfast
i put a set pf dalton dpy 60 gram weights red dalton spring secondary stock still does not seem to pull good turning 10300 to 10400 but our snow this year is like snot no traction
SMOKNZ
Re: Rx1 wheel updates
Got a pic of that setup?
factorystock70 said:Check out www.schmidtbrosmotorsports.com They do the cold air box mods and rejetting. I have an 05' Rx1 with about 2300 miles on it. I didnt have the air box mods done but I had them install about 4-6 more boggie wheels underneath the suspension where they need to be. 2 in the front arch rail. 1 to complete the 4 in the back axle. 1 on each side in the rear 2 inches ahead of the back axle and a few in between. Theese wheels will cause you to do a lil re clutching which he does before you get it back. Your not dragging your slides anymore, everything is free'd up and that alone is about 5 hp. Im throughly impressed.
factorystock70
2005 Yamaha RX1 wheel kit
Ok, here it is.
Ok, here it is.
