4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
I posted this on the RS forum but got no replies so I thought I'd post it here.
I need to pressure test my cooling system to see if I have a small head gasket leak. Does anyone have the testing kit that I can borrow? Or what might be my options. None of my local friends has a bore scope that I can check the cylinders for anything white looking.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Most auto parts stores have tools like this for rent. Put money down to use it and get your money back when returned. Basically using it for free.
sab2022
Suggest a cylinder leak down test kit - tells you if the loss of compression is due to things like worn rings, burned or stuck open valves (intake or exhaust) or a leaking head gasket. The kits are under $100.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Even with the smaller than "standard" hole like on my Vector? I'll have to check them out.Most auto parts stores have tools like this for rent. Put money down to use it and get your money back when returned. Basically using it for free.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Good idea, but I'm unemployed right now so the Warden wouldn't be happy if I spent MORE to fix my sled than I'm doing now. It's POSSIBLE that I have a small leak somewhere and a pressure test will at least hoses and connections.Suggest a cylinder leak down test kit - tells you if the loss of compression is due to things like worn rings, burned or stuck open valves (intake or exhaust) or a leaking head gasket. The kits are under $100.
My sled does have almost 24K miles on it.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
What makes you think you have a head gasket leak?
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Out of the blue on Saturday (before my header cracked) my digital temp gage went crazy which means it's low on coolant. I think I'm good about looking my sled over and was surprised that I was down so much on coolant. No visible leaks coming form under the sled. So with 24K miles on the sled, a hose or fitting could have a slight leak. Or I've heard of head gaskets going out on the 973 motor.What makes you think you have a head gasket leak?
Check the side heat exchangers near where the rear suspension cross shaft bolts to the tunnel.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
I had a leak where the RS cross-shaft bolt on my M10 rubbed into the exchanger. I have no clue how or why it loosened up. Took the shaft out, cleaned and regreased it. Used JB Weld as a fix to hopefully get me through the season. Will have it tig welded over the summer. Reinstalled the skid and so far so good after a 115 mile ride yesterday.Check the side heat exchangers near where the rear suspension cross shaft bolts to the tunnel.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Oh, and BTW. The testing kits you can rent at an auto parts store....none of them had a cap small enough to fit on my overflow bottle. Yamaha has a special part that fits and uses a standard pressure gage setup...per my dealer.
RobX-1
- Coldwater, OH
I know this kit came with various adapters and was expecting to have to use its universal one (ie. the tapered cone one) but then was worried it would be too long and would bottom out in the reservoir. Thankfully, the smallest adapter fit in the mouth of the reservoir of my 18 Apex where I was able to test holding pressure. It also worked when flushing the coolant in my 08 Apex as well.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
I wonder if your Apex has a larger opening? All three parts stores had similar kits and the local Yami dealer wouldn't loan theirs to me.
- 14K
