Sissi
- Jan 5, 2026
- Finland
- Other
- Yamaha RS Vector 2005
I got my vector engine now on the table. But i am not sure in which direction can i rotate the engine?
Tell me for example when i am watching it from timing chain side can i rotate clockwise or counter-clockwise.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Rotate it towards the intake side on the cylinder head. If you rotate it towards the exhaust you run the risk of the cam chain jumping.
Sissi
- Jan 5, 2026
- Finland
- Other
Do you mean towards the intake side when crowbar handle is towards up or down because that makes a lot of difference.Rotate it towards the intake side on the cylinder head. If you rotate it towards the exhaust you run the risk of the cam chain jumping.
RobX-1
- Coldwater, OH
Well, if you are familiar with clocks and such, how about as you are facing the primary, you want to turn it counter-clockwise. Does that help?
- Apr 17, 2003
- Menno, SD
- Menno, SD
Start the wrench at 12 and always go towards the intake side of the motor, doesn't matter what side of the engine you are on.
