jackback
Started up this fall first no low beams just high beams now neither, tail lights and dash lights work fine just no headlights chased all the wiring and fuses could it be the Relay or the Stator. Any help would be appreciated
Thank You
Thank You
josnow
- Dec 12, 2014
- CMass
- 2005 Rage
Did you change the bulbs?
jackback
No same bulbs as last year and they are good I checked them also
There is a 5 pin relay for the headlights beside the fuel pump relay in the left footwell.
jackback
Thanks Steiner have it off going to try that first likely the culprit as both high and low beam went out at different times, if the lighting coil on the stater had crapped out they would likely both have quit at once
Tank you for the reply
THKSNOW
Smooth Operator
- Aug 11, 2006
- 2013 RS Venture GT
When my stator went at 15,000 it would not start or fire at all, so I doubt that is the problem.
I also had the same issue on my 2006 attack and traced it to a broken wire (in the harness) near the coolant bottle. There is a bend in the harness that rubs on the frame and broke through. The main power wire was also half worn through and only a matter of time before it broke as well.
