apracing
- Feb 19, 2013
- new brunswick
- 2004 rx1 warrior 2006 apex gt 1979 enticer 340
just bought a 06 apex gt ,anyone know how to get control on the dash for the rear electric shock and then what control sets it ?? thks
Murse
- Sep 7, 2012
- Cornwall, Ontario, Canada
- 2011 Yamaha Apex Std Red
Settings button on dash, the center one I do believe of the three. Changes the dash icon from hand warmers to shock control. Left hand warmers button toggles the shock dampers from soft to hard. Lower the bars the softer it is the higher the stiffer it is.
Soldier'spapa
- Mar 21, 2006
- Naperville, IL
- 2018 Sidewinder Ltx LE 50th Anniversary
The button labeled "Mode" is used to toggle between grip warmer and shock adjustment. When pushed if you do not see a shock icon appear on the display, suspect a broken wire near the shock itself.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
Could be a broken wire in the tunnel. This is a common problem. Also check the fuse for the EC shock.
